I'm using MLV on tablet with small bluetooth keyboard. Would it be possible to add standard menu keyboard shortcuts? That would make it much more usable with keyboard.
Feature request: keyboard shortcuts to main menu items
Re: Feature request: keyboard shortcuts to main menu items
Have you checked out the Hot Keys under the help drop down menu in MLV ? There are several hot keys there to navigate through the logs.
Yes, all those work. But accessing basic menus like file->open requires mouse/touch.
File open is Ctrl + o
Compare to Ctrl + c
Trail Live File Ctrl + t
Eport Loaded Log as Ctrl + e
Other than those what options might you be looking for ?
Compare to Ctrl + c
Thanks for these. What I was looking for is the standard way a Windows app menus work. Pressing alt activates menu bar and then you can use arrows to browse menus. Or usually alt followed by f opens file menu and so on. These shortcuts are usually marked by underscore on menu item text. TunerStudio has these, but MLV does not.
