display of pointer on VE table with ITB load in MLV
I just went over to ITB load and when using MLV to view my log files the pointer on the VE table is in a different part of the table than were I'm seeing it on TS in reality. I mean the pointer seems to completly follow the map...
BTW : I've used the correct tune file...
Re: display of pointer on VE table with ITB load in MLV
what field are you using for Y axis ? is it "Load" field ?
ditto, opened a log. Set "Load" on the Y axis. The pointer follows the log on the table as if the Y axis was TPS. Graphed TPS vs Load on the scatter plot, It is a straight line.
It looks like MLV doesn't understand the ITB algorithm. ??
works for me can you post example files? what version of mlv are you using
here is the log and ITB tune. I am using MLV version 4.0.19.
Go to scatter plots, plot tps vs Load. 100% correlation.
MLV doesn't calculate load correctly.
Try the AN tune and you will see what I mean.
thanks
thanks
updated last post
was that log taken when the engine was running on the itb tune??? what firmware iv attached a short log of my bike on ms2 in itb see if the blue dot follows for you?
You are correct, the log was made in AN mode. Your log moves the pointer around correctly. I will have to make a clean log in ITB mode to tune the engine.
Thanks.
Thanks.
