display of pointer on VE table with ITB load in MLV
Yves
Post by Yves »
I just went over to ITB load and when using MLV to view my log files the pointer on the VE table is in a different part of the table than were I'm seeing it on TS in reality. I mean the pointer seems to completly follow the map...
BTW : I've used the correct tune file...
2swe
Re: display of pointer on VE table with ITB load in MLV
Post by 2swe »
what field are you using for Y axis ? is it "Load" field ?
1978 vw golf gti 16v itb cop full sequential MS2
1992 vw corrado 16v moonlight blue MS2
pkm123
Post by pkm123 »
ditto, opened a log. Set "Load" on the Y axis. The pointer follows the log on the table as if the Y axis was TPS. Graphed TPS vs Load on the scatter plot, It is a straight line.
It looks like MLV doesn't understand the ITB algorithm. ??
grom_e30
Post by grom_e30 »
works for me can you post example files? what version of mlv are you using
pkm123
Post by pkm123 »
here is the log and ITB tune. I am using MLV version 4.0.19.
Go to scatter plots, plot tps vs Load. 100% correlation.
MLV doesn't calculate load correctly.
Try the AN tune and you will see what I mean.
thanks
pkm123
Post by pkm123 »
updated last post
grom_e30
Post by grom_e30 »
was that log taken when the engine was running on the itb tune??? what firmware iv attached a short log of my bike on ms2 in itb see if the blue dot follows for you?
pkm123
Post by pkm123 »
You are correct, the log was made in AN mode. Your log moves the pointer around correctly. I will have to make a clean log in ITB mode to tune the engine.
Thanks.
