VE Analyze
Alfagta
VE Analyze
Post by Alfagta »
Hello,
does anybody know what "AFR Field" and the "EGO Correction Field" dropdown combobox is?
In the help there is nothing about these two fields.
I use MLV 4.0.19 as well as MLV HD 4.0.20.
Best Regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Re: VE Analyze
Post by LT401Vette »
Those are to change what fields are used for AFR and EGO Correction during VE Analyze. Generally you just use the default, but with some setups the MegaSquirt may be doing it's EGO Correction based on a different field, so this lets you over-ride the default selection.
For example if you have a dual table set up to use a different table and wideband for each bank, you would want to select the appropriate fields for which ever table you are tuning.
Alfagta
Re: VE Analyze
Post by Alfagta »
Hello,
thanks for explaining this.
Maybe you can add it to the help window.
Best Regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
