Marking logs in mega log viewer
Is it possible to mark the data logs? There is a feature in the motec log viewer that I fell in love with. You can put your drag strip tickets in a box and it marks on the log your 60ft, 330ft, 660ft, 1000ft, and 1320ft. Thanks
Re: Marking logs in mega log viewer
You can add a mark while capturing the log in TunerStudio, but what I think you are asking for is adding a mark after the fact in MLV.
There is not that now, but that would not be hard add. I'll put it in for the next release.
That would be great if you can add it. The motec log viewer actually has a box that pops up and it has spots to input your run increments from your time slip and automatically puts the marks on the data this way you know where on the track you where at that moment. It also helps keep track of the timeslip that matches that data file. Thanks
This was added for the next release...
The automatic marks is an interesting idea, I like it. At least for drag racers.
Awesome glad you could add it I can't wait for the next release. When do you for see it?
Currently working to get the next TS to beta. That should be quite soon, then I will button up a few things on MLV.
Would it be possible that in the same box you input your dragstrip time increments to have a few boxes to enter weather info? Would be nice to have temp/gow/altitude/density altitude/humidity/track temp etc. For future reference. Thsnks
