lamda delay on ve
nathanhardy
lamda delay on ve
Post by nathanhardy »
what exactly is one record? for the delay feature
98 VW golf gti vr6 turbo 8:5:1 cr ported and polished full ferrea race valves train 276 cams custom short runner intake Borge 366 sx-e turbo forge wossner pistons, balanced rotating mass, limited slip 6 speed deka 750Lbs injectors on ms3pro completed AWD swap
Paul_VR6
Re: lamda delay on ve
Post by Paul_VR6 »
Time delay of one record would mean that that the time for your wb to read an event (i use hitting a limiter) is exactly the time between two measurements. Two records is double that, three, etc.
-Paul
nathanhardy
im confused Paul so you use a fuel cut limit then measure the time till you see the change? not sure im follow the record stuff thoght
nathanhardy
p.s the tune is coming in nicely... had to much ae so it was causing problems as well as my PID setting were all screw up.. did some reading and changed a few things and its going good just wanted to double check my afr time delay
slow_hemi6
Post by slow_hemi6 »
Under Communications there is Data Rate and you will select x Reads/sec. If there is 10 reads per second then the time delay of one record should be 1/10th of a second. If it is 20 read/sec then the delay of a record is 1/20sec, and so on.
Cheers Luke
nathanhardy
thank you
