lamda delay on ve
lamda delay on ve
what exactly is one record? for the delay feature
Re: lamda delay on ve
Time delay of one record would mean that that the time for your wb to read an event (i use hitting a limiter) is exactly the time between two measurements. Two records is double that, three, etc.
im confused Paul so you use a fuel cut limit then measure the time till you see the change? not sure im follow the record stuff thoght
p.s the tune is coming in nicely... had to much ae so it was causing problems as well as my PID setting were all screw up.. did some reading and changed a few things and its going good just wanted to double check my afr time delay
Under Communications there is Data Rate and you will select x Reads/sec. If there is 10 reads per second then the time delay of one record should be 1/10th of a second. If it is 20 read/sec then the delay of a record is 1/20sec, and so on.
thank you
