I would like to propose the following idea.
Just as we have multiple dashboards in TunerStudio, and we can select between dashboards with the tabs on the bottom of the screen, please add multiple dashboards to MegaLogViewer.
Obviously, each dashboard setup should be able to be saved/loaded individually, just like in TS, and one should be able to save/load all the dashboards in a single file (master dashboard/"workspace").
That would allow one to easily switch between "Boost Tuning"/"Idle Tuning"/"Engine Safety"/etc dashboards.
Mutiple dashboards
Mutiple dashboards
The man behind MS Labs
Re: Mutiple dashboards
That has been on the todo list for some time...
I think there are some views in the upcoming TS to cover some of this.
To be clear, I'm not suggesting to add gauges in MegaLogViewer (although a log playback feature inside TS - using gauges - may not be a bad idea).
I'm only suggesting to have multiple tabs of graph sets.
Ok, that is different.
Should be quite doable.
Hi Phil,
any chance of doing this please?
Dimitris
Dimitris
