VEAL Adding and adding
So VEAL keeps adding fuel every time I run my tune and datalog through it I'm setting it so it corrects under 70 map max with a lag record time of 4 then saving and running that same log again on the saved tune at 70 min and a max 220 set at 1 record delay... My car runs into the 10's afr into boost especially when I shift, I'm also getting peaks on the VE table, my car doesn't seem to like more then 1 ms of adding fuel on the accel inrich.. I'm having the hardest time getting my afr's to be stable at steady state. I'm not stacking the logs and this problem only stated after a surge tank, Fpr and a walbro 450lph inside the surge tank fed by my stock in tank pump as a lift pump. Especially the peaks after the install of those components I will post a log and msq we I get to my laptop any help would be greatly appreciated thank you!
Re: VEAL Adding and adding
Lambda delay table
If it is set to default, VEAL will chase its tail until it passes out.
You're talking about the record slider correct? If so I run the log through veal twice once at 4 for under 70 kpa and again at 1 for above that.. I partly think that I don't have enough ae being the cause of the VE table spikes but I've difiently been confused why mlv just keep adding fuel especially after the better fueling setup. Is there a better way to tell if you're getting a Rick misfire from having too much ae? Thank you for your response I did learn last night that one record is one click on the arrow button so my delays look to be off alittle so thank you!
No, there is a table under lambda delay, in advanced settings, under VE Analyze Live tab of Tunerstudio
Yeah I know about that for some reason when click on it it will not open. That's partly why I've been using mlv instead of auto tune! Maybe Phil could shed some like on that little problem... I'm half tempted to just be content and wait till tuner three arives!!!'
The 2 pass approach is just what I generally do when using MLV, that should be ok.
Can you post / send a log file and msq. If it is adding fuel, there should be a reason somewhere in the log, the log will show where and why.
