update issue
update issue
I cannot seem to uodate mlv. It keeps getting stuck at 23% and just sits there till i get a error. Any ideas?
Re: update issue
Take a look in the task manager and make sure there is no other instances open could be a file lock.
Could possibly have to do with permissions, in that case right click on the MLV Icon then start MLV by click on run as administrator then try running the auto update and see if it completes.
Re: update issue
That happened to me recently. Ended up removing it and starting again. The fresh install updated OK.jsimmons wrote:I cannot seem to uodate mlv. It keeps getting stuck at 23% and just sits there till i get a error. Any ideas?
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Re: update issue
Ive tried all that already. Ill just uninstall and reinstall and see if that fixs the issueBrian H EFI wrote:Take a look in the task manager and make sure there is no other instances open could be a file lock.
