Lamda Target based off afr table
Hoping to get some help with a custom field i had one made for tuner studio that worked perfect but i would know how to do the same thing to get on in mlv
98 VW golf gti vr6 turbo 8:5:1 cr ported and polished full ferrea race valves train 276 cams custom short runner intake Borge 366 sx-e turbo forge wossner pistons, balanced rotating mass, limited slip 6 speed deka 750Lbs injectors on ms3pro completed AWD swap
Re: Lamda Target based off afr table
Calculated fields > Custom fields > Add Custom field.
Cheers Luke
Cheers Luke
Got that part but i do not know the expressions for it. I guess i should have paid better attention when i was in math classslow_hemi6 wrote:Calculated fields > Custom fields > Add Custom field.
Thank you tho!
Phil has some info on his website about the expressions. I looked it up a couple of years ago. http://www.efianalytics.com/MegaLogViewer/formulas.html
Be something like, Fied Name: AFR Target1 Formula: [afrtgt1] .
Cheers Luke
Cheers Luke
What are you trying to calculate?
So I'd like to graph lamda target on mlv so I can tune using "have over what" easier without having to use my horrible math skills.
Are you operating in Lambda or AFR for your project? Lambda for gasoline is AFR/14.7. If your project is in AFR and you want to convert then you would have a field name like "Lambda Target" and the formula would be something like [AFR Target 1]/14.7 .
Cheers Luke
Cheers Luke
I'm just learning but I want to learn in lamda I will try that
You can have almost all of your project in lambda if you set it as lambda in, File > Project > Project Properties > Settings
AFR target table then becomes a lambda target table.
Cheers Luke
Cheers Luke
Yes but it does give me a lamda Graph on mlv. If you have actual and target it's very easy to she the percentage of fuel that needs to be remove with little to no math.
