table for output monitoring
I'm sure this is somewhere but I haven't found it . I am operating relays from JS1 and JS3.im also inputing switch ground to JS7. Id like to look at those in the logs. Is that doable? is there a list of status or sensor parameters somewhere ?
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: table for output monitoring
Tuner studio manual has the full list of datalog fields. http://www.msextra.com/doc/pdf/html/Meg ... .4-57.html and the page after. http://www.msextra.com/doc/pdf/html/Meg ... .4-61.html and the page after.
Thank you Luke.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
You are basically looking for the relevant number result for the port. JS0 should be IAC1 which is in portmj. Being equivalent to 1 any odd number result for portmj means it IAC1 active and any even,or zero means it is not active. But whether active is on or off for your device could also depend on the whole IAC1a IAC1b complimentary switching arrangement. Complicated initially but you will work it out.
I need to watch portmj but I also need to watch JS7 which it looks like is porteo which I don't see as a field I can see in the log?? I see portmj and its going nuts so I need to watch the input which is JS7. For instance...I'm trying to figure out why the compressor and idle control keeps jumping on and off when the ac on input is switched on in this log .
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
If you have the registered version of MegaLogViewer you can add a calculated field to pick out one bit.
e.g. create PORTE0
[porteh] & 1
e.g. create PORTJ1
[portmj] & 2
e.g. create PORTE0
[porteh] & 1
e.g. create PORTJ1
[portmj] & 2
Yes I have the registered product both TS and MLV. I just suck at the whole language thing LOLjsmcortina wrote:If you have the registered version of MegaLogViewer you can add a calculated field to pick out one bit.
e.g. create PORTE0
[porteh] & 1
e.g. create PORTJ1
[portmj] & 2
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Ok I created the ports as PORTE0 = [porteh] & 1 PORTJ1 = [portmj] & 1 PORTJ2 = [portmj] & 2 . I'm using IAC1b and IAC2b to control the compressor and 2 fans and using JS7 as an input to turn the compressor on and the tune turns on the rad fan when the Ac is on . I'm getting a problem where the AC compressor is intermittent and the idle valve duty is dipping down as if you turned off the ac and fans but I'm not seeing it reflect as commands on the log. I do see the indicators come on and off on the TS screen while its happening . The ac light blinks on and off intermittently as well as the fan light which is why I'm trying to see the input which should be PORTE0. Did I do it right?
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
