Can't see log
Can't see log
I just installed the TS and ML viewer. I made a short log. When I go under "data logging" in the TS, I opened the "view with MegalogViewer. The files show and I click the most recent. Then after I hit "open in ML window the window opens but it says "Log file not found". Further occurrences of this error will be suppressed. Any help out there? Thanks guys!!!
Re: Can't see log
What OS are you using?
Are you using the default location for TunerStudioProjects folder in the Documents folder?
