Pointer/Tail on VE and Timing tables MIA
corvelton
Post by corvelton »
So i recently supercharged my car and expanded my VE and timing tables on it up to where i think the limits are gonna be for the blower. I drove around and logged a few min of casual driving along with one WOT pull and i went to my logs and found it logged the run, But i have no pointer on the VE table or Timing table. Is there a hotkey to turn it on/off that i accidentally hit? I cant find a on/off option for the pointer anywhere. Thanks in advance.
LT401Vette
Re: Pointer/Tail on VE and Timing tables MIA
Post by LT401Vette »
No, it should always be there if the engine is running..
What version TunerStudio?
What firmware?
corvelton
Post by corvelton »
TS version V2.6.14 , MSX firmware # 3.3.3
LT401Vette
Check what your Default Y-Axis Field is set to under:
Options --> Default Y-Axis Field
Also check if there is a Y-Axis over-ride set.
Right click on the Y Axis of the table.
If it says "Clear Y-Axis Override", select it.
If it says "Set Y-Axis Override" then there is no override set.
corvelton
Post by corvelton »
LT401Vette wrote:Check what your Default Y-Axis Field is set to under:
The Y Axis is set to MAP and there is no Y axis set, "Set Y-Axis Override"
corvelton
Post by corvelton »
I turned Y Axis Override on to 185 (My max KPA) and its working again! :D Whats the point of the override?
LT401Vette
It should be set to a number... That should be set to the log field name that the Y Axis tracks to.
So for standard Speed Density the default Y Axis would be set to MAP.
There would be no Y-Axis override.
However, if you have another table that uses a different Y Axis field, you would set the Y-Axis Override to the correct tracking field name for that table.
