how can I display ego voltage in Megalogviewer (narrow band setup) ?
Ego voltage does not appear in drop down.
how to display ego voltage ?
Re: how to display ego voltage ?
Firmware?
MS3 1.4.1
In TunerStudio, go into Project Properties.
(Press CTRL+P)
In the Settings Tab, under "Oxygen Sensor / Display"
select "Narrowband Sensor - Volts"
Now future logs will contain an O2 field for each Narrowband sensor set up that will be in Volts.
(Press CTRL+P)
thanks alot!
