Slow and choppy zooming in/out of logs
Re: Slow and choppy zooming in/out of logs
Part of the scaling up is the line thickness...
The graph line is 1 px thick, but at 150% it scales up to 2px. For what ever reason, the api's to draw the line do not like that while at those settings.
I just put put a new version of MLV HD 4.1.09 that should take care of this.
Yup that totally fixed it. Thank you.
Are you still going to make opengl a rendering option? I would be interesting to see if there is a performance difference between it and DirectX.
Yes, I forgot about it today.Are you still going to make opengl a rendering option? I would be interesting to see if there is a performance difference between it and DirectX.
There is one in TS. Some things work better, then on some computers there are rendering issues
LT401Vette wrote:Yes, I forgot about it today.Are you still going to make opengl a rendering option? I would be interesting to see if there is a performance difference between it and DirectX.
I tried it out in TS. Works well but CPU utilization is much higher, which might mean lower battery life. It would help if there was an fps counter to see any difference in performance.
One more bug to report. Now when you start the log playback, the displayed values blink.
There is if you edit the TunerStudio.properties file, uncomment the line:I tried it out in TS. Works well but CPU utilization is much higher, which might mean lower battery life. It would help if there was an fps counter to see any difference in performance.
#dashShowFPS=true
by removing the #
dashShowFPS=true
Well according to the fps counter openGL does seem to perform better, however the old Linux laptop still seems to smoke the Windows version of the app running on newer hardware. I get 60 fps at 25% core on Linux and about 50 fps at 70% core on Windows. :/
An fps counter would be cool in MLV if that's an easy thing to add.
Also I think the bug we discussed here is in the integrated log viewer in tuner studio as things get a bit choppy in there.
It does...Also I think the bug we discussed here is in the integrated log viewer in tuner studio as things get a bit choppy in there.
Don't forget how much more data windows is painting with that dpi depending on what resolution you are set to.. But it does seem windows still doesn't like scaling.Well according to the fps counter openGL does seem to perform better, however the old Linux laptop still seems to smoke the Windows version of the app running on newer hardware. I get 60 fps at 25% core on Linux and about 50 fps at 70% core on Windows. :/
There is one as above.An fps counter would be cool in MLV if that's an easy thing to add.
The blinking I will get a fix out for that too.
