Lamda target/lamda
nathanhardy
Lamda target/lamda
Post by nathanhardy »
How can i calculate and set it up so i can see lamda instead of afr and lamda target instead of afr traget on my graphs... i find it easier to use lamda to do the math.
Please help!
nathanhardy
Re: Lamda target/lamda
Also how do i scale it so my actual and target are on the scale...
nathanhardy
Figured out the lamda but it wont let me do this for the lamda target....AFR Target 1/14.7
slow_hemi6
Post by slow_hemi6 »
It's fussy with syntax. Try [AFR Target 1]/14.7
Cheers Luke
motthomas
Post by motthomas »
You need to change your wideband settings in project settings. Then it will use Lambda instead of AFR.
Sent from my GT-I9305 using Tapatalk
nathanhardy
slow_hemi6 wrote:It's fussy with syntax. Try [AFR Target 1]/14.7
Thanks everyone but this was the ticket? :yeah!:
