Hi guys,
i just bought megalogviewer HD since i've replaced my injectors with bigger ones and it though that i would be of great assistance in tuning the VE correctly
i'm running a ms1 v2.2 with updated firmware so i could cancel the ford EDIS.
my wideband is a techedge diy one
the problem i'm having is when i want to analyze the datalog it says i need to select an O2 sensor from the menu,
the only place i can find that is in the calculated fields drop down menu.. and i can change whatever i want, the problem just stays the same.
i've checked the internets and the help section of megelogviewer but that wasn't of great help to me
anyone who can help me out please?
megalogviewer o2 sensor selection SOLVED
Re: megalogviewer o2 sensor selection
For a normal WB O2 connection on MS1, you should be able to set the WB Sensor under:
Calculated Fields --> Wideband O2-AFR Front
Then in the VE Analyze dialog make sure it is pointing at the appropriate AFR Field in the Advanced side of the VE Analyze dialog.
Re: megalogviewer o2 sensor selection SOLVED
i tried it again and it didnt work.
i uninstalled and reinstalled the program and now everything seems fine!
thanks for the help
thanks for the help
