Maximum log file size?
E4ODnut
Post by E4ODnut »
What is the maximum log file size that MLVHD can handle?
Robert
'53 VW Beetle Street Baja dual port 1641 MSnS-Extra
LT401Vette
Re: Maximum log file size?
Post by LT401Vette »
That depends on a few things...
- How Many fields are in the log
- 32 bit vs 64 bit
- How Much RAM is on your PC
For a quick test I just used an MS3 data log with 517598 records. It is 241MB.
Just starting MLV nmormal, it crapped out about 2/3's through.
By starting it with the command:
java.exe -Xmx2048m -Xms1024m -jar HogLogViewer.jar
To allow it to use up to 2GB of RAM, then it loads it right up.
However, what I need to look into is that the exe should have been using the larger memory start up command on it's own with a computer that has 16GB of RAM. I need to look into why it didn't.
LT401Vette
It appears the exe is detecting and setting memory right on my windows 7 computer, but not my Windows 10 computer.
E4ODnut
Post by E4ODnut »
Thanks for the quick response Phil. I don't think file size will be an issue for me because I doubt that I will even come close to 200 megs.
Robert
