I had an interesting "oopsie" happen last night. After changing some settings in MLV and later exiting, the program would no longer launch!
I've got it set for 5 graphs with 5 traces each and tracked the problem down to setting the color for trace 25. If I attempt to do that, the color doesn't change, and when I exit and try to relaunch MLV the splash screen appears for a few moments but that's it.
I found that by editing the mlvUser.properties file and removing the line that says "graphForeColor24=something" the program will launch again.
I'm attaching a log file with a successful launch, then a change of trace 25 color, then closing the program, and an unsuccessful attempt to relaunch it. And the properties file, renamed so the site would accept it.
MLV 4.1.10 crash setting graph color
Eric Law
Re: MLV 4.1.10 crash setting graph color
Interestingly...
Using your mlvUser.properties with the 4.1.10 it does not open... But in the debugger it works fine..
I did have a similar issue a bit back that got fixed, did it not make it in somehow?
I'll have to look into it.
I've got the exact same behaviour as you, elaw.
My solution also was, to only set the color for 24 graphs and leave the 25. where it was.
That happens on TS for Mac AND Windows!
