EGT's in Megalogviewer
Noisy Toys
Post by Noisy Toys »
I'm at a loss trying to figure out how to set Megalogviewer so that I can see graphs for EGT, oil pressure and fuel pressure. I have the necessary hardware properly setup in TunerStudio but none are options for me in the Megalogviewer drop-down menus for any of the graphs. Anybody want to help out a newbie?
Buck
LT401Vette
Re: EGT's in Megalogviewer
Post by LT401Vette »
Please post an msq.
:msq:
Noisy Toys
Oh yeah, knew I was forgetting something.....
LT401Vette
It looks to me like it should indeed be data logging EGT's.
Starting a new Data log in TunerStudio, that log does not have 4 fields: EGT1, EGT2, EGT3, EGT4?
Can you post a short log?
Noisy Toys
I just figured it out, I think. Not knowing what else to do I setup gauges on a dashboard in TS for the inputs I want to log. Now those inputs are available in MLV but when I record a new datalog and try to download it I get a "timed out" error message.
Two steps forward, one step back. At least it's progress.
LT401Vette
Are you looking at regular data logs or SD logs?
Noisy Toys
SD logs.
LT401Vette
That is a different animal.. Then it won't log unless you have the field selected to log..
What sort of a timeout message?
Noisy Toys
The message I get says:
Error downloading LOG0021.MS3
Controller Instruction failed!
Error:
Timeout after:601ms. requested timeout:600, Expected bytes:3, bytes read:0
LT401Vette
With any file you try to download?
What type of connection are you using?
