TPS ADC logging backwards
andrew1988
Post by andrew1988 »
Im having an issue logging TPS ADC.
I am using ms1 extra with tunerstudio and i am tuning using alpha-n.
the y axis of my ve table ranges from 100 at closed throttle and 250 wot.
when i take a data log then open it in megalogviewer it shows idle at 250 and wot at 100 adc.
Has anybody seen this before?
i have tried both a ccw tps and a cw tps and tried wiring it around the opposite way which just makes the adc in tuner studio operate backwards and the data log still sees idle as 250 tps adc.
I am lost as to where to go from here.
any help is appreciated.
2swe
Re: TPS ADC logging backwards
Post by 2swe »
do you logg the TPS ADC directly from MS, or is the TPS ADC calculated by MLV ?
1978 vw golf gti 16v itb cop full sequential MS2
1992 vw corrado 16v moonlight blue MS2
andrew1988
i didnt know there was two ways. I am using the standard logging profile that tuner studio has in it.
whittlebeast
Post by whittlebeast »
:msq:
In Tuner studio, does your TPS work as expected?
Andy
2swe
Post by 2swe »
I have no idea what is "standard logging profile", but few years back when I tuned MS1extra, I used to add 2 rows to the end of msns-extra.ini
Code: Select all
entry = tpsADC,            "TPS ADC",       int,        "%d"
entry = TargetAFR,       "AFR Target",   float,     "%.3f"
this adds TPS ADC and AFR Target to your datalogs, very useful..
Post by Matt Cramer »
Check the TPS voltage - is it higher at full throttle than closed, or is the voltage backwards too?
andrew1988
whittlebeast wrote::msq:
Andy
the tps in tunerstudio works as expected
2swe wrote:I have no idea what is "standard logging profile", but few years back when I tuned MS1extra, I used to add 2 rows to the end of msns-extra.ini
Code: Select all
i think this might be my problem. Where is it that i can add these in?
Matt Cramer wrote:Check the TPS voltage - is it higher at full throttle than closed, or is the voltage backwards too?
Ill have to check this on the weekend when i can work on the car
LT401Vette
Post by LT401Vette »
I'm guessing you are using the "TP ADC" field calculated in MLV.
Select the menu:
Calculated Fields --> Optional Fields 2 --> TP ADC
Uncheck that, then re-check it
You will be prompted for your ADC values at Maximum and Minimum.
I'm guessing you entered them backwards the 1st time as Maximum is on top.
2swe
Post by 2swe »
TunerStudioProjects / YOUR PROJECT / projectCfg / mainController.ini ... it's the end of the file.
andrew1988
thank you ill definitely give that a try.
LT401Vette wrote:I'm guessing you are using the "TP ADC" field calculated in MLV.
Select the menu:
this was the problem. I cant believe i did that.
