Search on condition?
elaw
Post by elaw »
Hey... have you ever considered adding a "search on condition" feature to MLV?
I'm going nuts trying to track down issues my car is having transitioning from overrun to idle. It would be tremendously helpful if I could do a search for "[RPM] > 1400 && [RPM] < 1600 && [TPS] < 0.3". Then I could just keep hitting F3 to see all the different times those conditions are met.
Eric Law
Re: Search on condition?
Post by LT401Vette »
Agreed... Someone else requested this a couple days ago also.
Oddly enough when I went to the code, the menus were already there but commented out.
The final search method looked like this:
Code: Select all
    public boolean searchExpression(){
    	// implement this it would be handy
So apparently I intended to put this years ago and didn't :-P
It is now implemented.
elaw
Post by elaw »
Fantastic... thanks! :D
Eric Law
elaw
Post by elaw »
Phil,
I just updated to 4.1.12 and found the "search by expression" function there... thanks!
There is however one little hiccup. If I use that function and find a point where the data matches, as soon as I try to reposition the cursor using the arrow keys it jumps back to where it was before I did the search. If I reposition the cursor with the mouse that does not happen.
Also not a bug but... it would be really cool if search expressions could be named and saved somehow... or even if it just remembered the last expression when you close the program.
Eric Law
bkubisht
Post by bkubisht »
In addition to the quirk eLaw has regarding arrow keys... the custom expression search can't be repeated with F3. It just uses whatever the most recent non-custom expression search was.
A search feature I'd like to have for composite logs would be to find the next point where it lost sync. That would be useful the next time I've got a comp log with 263 frames to look through. :)
I'm glad you pulled up this old thread. Some how Eric's bug issue fell off my radar.
I have fixed that and fixed the F3 search next. It will be in the next release.
Matt, I will have a look at that as well, it does sound useful.
