Added two sensors under the generic sensor inputs. Gave them a source. ONe is spare adc and the other o2 2. Both have field names added etc. Burned to controller.
I can see them on my tunerstuidio dash fine, but they do not show up anywhere on megalog viewer. Im sure im missing a step somewhere.
Thanks.
Please see attached msq and log
Having issue seeing added 0-5v sesors in log
Re: Having issue seeing added 0-5v sesors in log
I'm guessing you datalogged this using the SD card? You do not have those fields selected to log in the settings.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Yes, that does look like a small subset of the available fields. Either it is from an SD card or a small set is selected in Logging Profiles.
Yes it's from a sd card. Am I missing where to add the fields. I even asked a friend for his log today and his stuff shows up fine.
Is it under the sd card settings?
Yes
Datalogging -> SD Card Datalogging -> Log Field Selection
Personal Vehicle:
Personal Vehicle:
That would explain it. I figured it would be in the megalog setting not tunerstudio. I'll mess with it tonight. Thanks guys
