I'm confused. When I select Hp from the drop down menu, then fill in the fields for hp and reload the log. Should I have a selectable field from the graph drop down menus? I've tried this multiple times and no luck getting to select a parameter. I have speed in the log, so I should be able to calculate hp correct? Where should I have to enter gear ratio and tire size etc? I havn't found a place in MLV or shadow dash to input these items. I've tried to upload a log file, but they are all too big.
As always, Thanks, Steve
HP from a shadow dash log
Will race for food, or water, or for just the heck of it. I might even race for cash.
Re: HP from a shadow dash log
When I try to input wheels size etc in ts ultra, all of the fields are greyed out when I select userspeedmph. After blowing a wastegate diaphragm at the dyno, I'm trying to finish this thing up on the road.
If all the fields required to create the HP field aren't available, it won't show up.
Is it the "HP" field or the "VSS HP" field not showing up?
HP should only require RPM and TP
For sure the HP. I can select ut from the drop down, fill in the required data, but it doesn't show as a field to select in the logs.
There were others as well, but I would have to go back and play with it some more to remember which ones.
If it isn't showing up, my best guess is that it isn't mapping one of those fields correctly.
I really need to see a short log to know for sure.
I have some logs at shadowlogger.com can you download them on your end? They are too large to attach here.
