Megalogviewer 4.1.15 - Apple OSX
In the Scatter-plots section, the vertically written description of the Y-axis, on the left of table graphs doesn't change when a different Y-axis log-item is chosen.
It takes a 'redraw' of the graph-window to show the new selection in the vertical text. To force a redraw, it simply takes hiding or showing the filters, after which the vertical text is shown correctly again.
Bug: MLV OSX - Y-axis description not updated
Re: Bug: MLV OSX - Y-axis description not updated
I have a Macbook Pro and I havent come across this issue before. Maybe a graphics issue...? If not have you tried updating your MegalogViewer to the newest version to see if that alleviates the problem?
Wubba Lubba Dub Dub!!! oh. yea...
1985 Toyota Corolla 20V 4AGE MS3X Seq. Fuel/Spark...
1990 Eagle Talon TSi AWD 4G63 MS3X Seq. Fuel, Batch Spark...
Issue still present in 4.1.17.
It is fixed for the next release.
