MLV Fields min/max too many
When is MLV going to allow access to edit all of the min/max values? Currently the dropdown menu is too large to fit on my screen, so I have edit the config file by hand instead or add them again if I want to change the numbers.
Also, as a feature request, it would be easier to double click on the min/max numbers in the graph section and edit that way.
Re: MLV Fields min/max too many
Something like:
This is actually in MegaLogViewer HD
Looks interesting.
Any thoughts about splitting up the existing drop-down menu so it will fit on my screen?
This is what I'm referring to:
JamesI can repair or upgrade Megasquirts in UK. http://www.jamesmurrayengineering.co.uk
The easy access to field settings is one of many added features that shows up with going to MLV HD.
Yes, I know of the trouble...
There are multiple solutions here...
1) Break the menu into groups with a maximum number of entries.
2) Use the field level menu's like MegaLogViewer HD does
3) Only show the min / max menu for fields that exist in the currently loaded log.
TunerStudio MS Ultra uses option 3 to avoid being over taken.
Try the much improved Min Max Editor in 4.1.17
Looks good! Thanks.LT401Vette wrote:Try the much improved Min Max Editor in 4.1.17
Any chance of getting filters in an alpha sort order. I have about 30 of them all in random order.
Andy
Andy
