MegaLogViewer
eman911
MegaLogViewer
Post by eman911 »
Can someone direct me to a user manual or tutorial for MegaLogViewer? I can't seem to find anything useful in the help file or online.
whittlebeast
Re: MegaLogViewer
Post by whittlebeast »
eman911
Re: MegaLogViewer
Post by eman911 »
I glanced through that earlier but it is geared to reading the logs. I need information or instruction on how to capture, save, import to MLV, and display the data. Once I get that down I can start worrying about interpretation.
nathaninwa
Re: MegaLogViewer
Post by nathaninwa »
In the "forum help page" link above, scroll down a little and it walks you through data logging
eman911
Re: MegaLogViewer
Post by eman911 »
Are we looking at the same topic? I just read 6 pages and nowhere do I see any sort of instructions or tutorial on how to use the software.
I assume that since the only references on the MLV site are a sales pitch for MLVHD and a blank users manual that this is all top secret stuff.
I'll try a few direct questions.
When logging is started in TS what data fields are collected?
When I open MLV I get 2 dialog boxes, one says it cannot load the full log due to a size restriction on the basic software. If the log is bigger than what is allowed what is displayed? Is it the beginning, middle , end or some random snippet? The second tells me it cannot display the graph until I define the Y axis in the options menu. How do I select a Y axis based on a list of 3 letter abbreviations?
I would like to view RPM, AFR, trigger signal and MAP to start with. None of these are available on the pulldown menu. How do I select them?
whittlebeast
Re: MegaLogViewer
The free version of MLV has something like a 500 record limit. The $30 registered version gives you unlimited length MS logs. The $40 MLVHD version gives you Histogram views and it will open several hundred other data log formats off almost any system ECU programmer like HPTuners.
LT401Vette
Re: MegaLogViewer
Post by LT401Vette »
MegaLogViewer MS has no size limit, HD does.
What type of manual are you looking for?
One on how to use MegaLogViewer or one on how to tune the car?
