MLV Variable selection presets
mrx79
Post by mrx79 »
maybe it's a dump question, but is it possible with MLV to save the currently selected variables in the graphs to a file and reload it later?
For example save ourself a lambda related and maybe a knock or ignition or CL idle related set of variables which can be loaded easily to switch "views".
Maybe also with changed variable min/max limits would be perfect. For example in normal log analysis rpm should be from 0-redline.
For a CL Idle optimized view only 0-1500rpm is a more suitable range.
If all these settings can be saved and loaded easily to a file with a few clicks would be a good feature.
Maybe something like this already exists, in this case i've overlooked it. Then please just give me a hint where to find it ;-)
Best regards
Honda CRX B16A1 Turbo | MS3 running | pre1.5.1 beta7 Firmware | 24/1 Dual Wheel | COP ignition | 725cc ID injectors
LT401Vette
Re: MLV Variable selection presets
Post by LT401Vette »
In the normal trace viewer, there are quick views that allow you to save the currently selected fields.
In the Histogram / Table generator, there is a "Saved Histogram Views" button that allows you to save a Histogram setup.
In scatter plots there is no way save a view. That is getting added shortly.
mrx79
Post by mrx79 »
thanks a lot, i just did not have seen this option ;-)
But thats what i was looking for.
