MLV HD also doesn't start - same problem with Win10
Zaphod
Post by Zaphod »
Hi Phil,
could you please apply the same fix for the no start problem to MLV (HD) as you did to TS with the latest beta.
Splash screen comes - then no start.
Edit: Deleting the GodMode folder fixes the problem...
Sven
fun is not a straight line
Sven
Re: MLV HD also doesn't start - same problem with Win10
Post by LT401Vette »
Yes, we are on that...
We should have the update for MLV's out today.
Ok, 4.1.17 is up and covers this windows 10 issue.
trbolexis
Post by trbolexis »
There seems to be an issue with the newest version failing to run after splash on my LTSB windows 10.
Any fix?
trbolexis
Post by trbolexis »
4.1.17 seems to have an issue loading again.
.txt file attached.
trbolexis wrote:4.1.17 seems to have an issue loading again.
.txt file attached.
Try renaming the file:
c:\Users\[YourUserName\.efianalytics\hlv.properties
You will also need to delete the bak file:
c:\Users\[YourUserName\.efianalytics\hlv.properties.bak
That will put it back to the defaul settings.
If you send me that file, I can see exactly what setting it messing it up on start up.
trbolexis
Post by trbolexis »
I had one in there name .bak already. So I renamed to bak2.
I'll attach both files here.
Unfortunately, after renaming to .bak (and deleting the original .bak file) MLVHD still fails to "open" after the splash screen.
Both files had .txt extension added to upload.
and the hlv.properties was deleted?
That should set it back to the defaults. You log looked like it was making an error while initializing a user setting.
Same stack in the log?
It might be faster to work straight with support <at> efianalytics.com
trbolexis
Post by trbolexis »
I did delete the original .bak with no success.
Would it be best for me to email?
trbolexis
Post by trbolexis »
I deleted all hlv.properties, and then the program loaded; creating new versions.
Thank you!
I have used your properties file to find the problem and fixed it for the next release.
Also have removed the line that cause the problem from the attached file so you don't loose all your groups and what not.
