MLV HD also doesn't start - same problem with Win10
Hi Phil,
could you please apply the same fix for the no start problem to MLV (HD) as you did to TS with the latest beta.
Splash screen comes - then no start.
Edit: Deleting the GodMode folder fixes the problem...
Sven
Sven
fun is not a straight line
Sven
Sven
Re: MLV HD also doesn't start - same problem with Win10
Yes, we are on that...
We should have the update for MLV's out today.
Ok, 4.1.17 is up and covers this windows 10 issue.
There seems to be an issue with the newest version failing to run after splash on my LTSB windows 10.
Any fix?
Any fix?
4.1.17 seems to have an issue loading again.
.txt file attached.
.txt file attached.
Try renaming the file:trbolexis wrote:4.1.17 seems to have an issue loading again.
.txt file attached.
c:\Users\[YourUserName\.efianalytics\hlv.properties
You will also need to delete the bak file:
c:\Users\[YourUserName\.efianalytics\hlv.properties.bak
That will put it back to the defaul settings.
If you send me that file, I can see exactly what setting it messing it up on start up.
I had one in there name .bak already. So I renamed to bak2.
I'll attach both files here.
Unfortunately, after renaming to .bak (and deleting the original .bak file) MLVHD still fails to "open" after the splash screen.
Both files had .txt extension added to upload.
and the hlv.properties was deleted?
That should set it back to the defaults. You log looked like it was making an error while initializing a user setting.
Same stack in the log?
It might be faster to work straight with support <at> efianalytics.com
I did delete the original .bak with no success.
Would it be best for me to email?
I deleted all hlv.properties, and then the program loaded; creating new versions.
Thank you!
Thank you!
I have used your properties file to find the problem and fixed it for the next release.
Also have removed the line that cause the problem from the attached file so you don't loose all your groups and what not.
