What is the difference between Base Spark Advance and Spark Advance? Attached is a screenshot of a datalog, and you can see a difference of 1.2 degrees between the two. Which one should be used to show real time Spark advance. Is Base Spark Advance before any corrections are made? Engine temp is a bit high on this car ( 201 F ) and it may be pulling some timing.
Note in Graph #2 at the cursor line, the traces are identical, but the values on the right hand side vary. At cursor line of 83.078 seconds , Base Spark Advance is showing 38.1 degrees, but Spark Advance shows 36.9 degrees. Trace lines look identical through log, but values differe. Why is that?
Attached are a screenshot of the above time period in the Datalog. Edit: Datalog is too big to upload directly. Exceeds 1mb. Zipped datalog in Reply below.
Base Spark Advance vs Spark Advance
Last edited by BlackBird_SR71 on Fri Aug 11, 2017 12:39 pm, edited 1 time in total.
Re: Base Spark Advance vs Spark Advance
Had to Zip Datalog as it was too big to post directly.
Base spark advance is from the tables. Spark Advance is the final figure after any modifiers.
Take a look at the Spark Calculations Summary page in TS.
Thanks James.
