Page 1 of 2
How Do I Configure the Graph 4 Traces?
Posted: Fri Sep 29, 2017 4:16 pm
by NigeT
Please see the attached screenshot. The Graph 4 traces dissappear off the bottom of the pane and I can see no scroll bar.
Thanks.
Re: How Do I Configure the Graph 4 Traces?
Posted: Thu Oct 12, 2017 1:27 pm
by NigeT
Please could someone tell me how to scroll down the graph selection pane. I can't seem to find a way to make MLV HD work currently.
Posted: Thu Oct 12, 2017 2:35 pm
by LT401Vette
You need to use a smaller font or have a bigger screen it seems..
Perhaps I should try putting a scroll bar under it..
Alternatively, you could try turning on "Quick Trace Selection" under the View Menu.
Then you select traces by clicking on the readout below.
Right click to direct it to a specific graph.
Posted: Thu Oct 12, 2017 4:49 pm
by NigeT
Thanks Phil, didn't think of making the font smaller. It's an XPS 13 with 4k display. I'm having loads of problems with UI element sizing, not limited to TS and MLV.
Posted: Fri Oct 13, 2017 8:25 am
by LT401Vette
Hmm, MLV should handle the font scaling, it may be over shooting here?
Posted: Fri Oct 13, 2017 10:25 am
by NigeT
Here's an example - first pop-up dialog I see.
Posted: Fri Oct 13, 2017 10:27 am
by NigeT
Maybe this gives a better idea - MLV full screen.
Posted: Fri Oct 13, 2017 10:30 am
by NigeT
Selecting different values for Options->Font Size doesn't seem to do anything.
Posted: Fri Oct 13, 2017 2:51 pm
by LT401Vette
I need to take a look at this..
The high DPI screens was a PITA a while back where all the fonts in MLV were itty bitty. That is taken car of, but it may have broken the Font Size selection beyond the Tuning Panel Tables.
Posted: Sat Oct 14, 2017 4:42 am
by NigeT
Just FYI, resizing that pop-up doesn't make it more usable.
Posted: Sat Oct 14, 2017 4:56 am
by NigeT
Now my graph lines have disappeared.
Posted: Sun Nov 05, 2017 5:58 pm
by NigeT
The trace graphs have disappeared again.
- 2017-11-06.png (372.51 KiB) Viewed 1126 times
MLV is becoming unusable for me. Last time this happened I think I had to download and install again, but I don't have enough spare time to keep doing that.
Posted: Mon Nov 06, 2017 6:58 am
by LT401Vette
What size font do you have it set to under:
Options --> Font Size
Posted: Mon Nov 06, 2017 5:54 pm
by NigeT
LT401Vette wrote:What size font do you have it set to under:
Difficult to see in the dialog, but looks like 30.
I think that somehow the graph had zoned out to the point that the whole trace was in the left pixel of the graph! I don't know how this would have happened because I almost always have the graphs zoomed to maximum. Only found this by attacking controls at random in desperation.
Just tried find size at 8 instead but it only seemed to affect the Graph N headings in Quick Views.
Thanks, Nigel.
Sent from my E6853 using Tapatalk
Posted: Tue Nov 07, 2017 8:27 am
by LT401Vette
In your Windows display properties what text size do you have set?
Posted: Sat Nov 11, 2017 4:17 pm
by NigeT
LT401Vette wrote:In your Windows display properties what text size do you have set?
Meant to check today and forgot, sorry. Will check next weekend when I'm back from working in the US.
Sent from my SM-N950F using Tapatalk
Posted: Sat Nov 25, 2017 2:51 pm
by NigeT
Finally remembered to check this. I've been using the default setting of 250%. I'm using the recommended resolution of 3200 x 1800.
Thanks,
Nigel.
Posted: Mon Nov 27, 2017 9:41 am
by LT401Vette
The latest version of MLV (4.2.04) has a scroll bar under the field selectors if needed, so you should be able to get to the 4th graph now.
Do you font sizes look way too big on that PC? They do in the screen shots, but I am looking at them on a 1080p 100% scaling PC, so the high DPI screenshots would...
I'm trying to figure out whether MLV is making the fonts too big, or you just don't have enough screen space..
Posted: Wed Nov 29, 2017 4:58 pm
by NigeT
So the thing is that some dialogs have huge text, some have tiny almost unreadable text and for some the layout makes them unusable. I tried to attach some sample images, but some were too big for the forum and then we I cut them down I found I was limited to 3 anyway.
Posted: Wed Nov 29, 2017 5:01 pm
by NigeT
A couple more, the last being Opera browser which looks pretty good generally.
