Changing the third and fourth graph colors
vw_chuck
Post by vw_chuck »
I selected to display 4 graphs(16 parameters) on screen but it only allows me to change the color for the first 8 parameters color? How do I change the other 8 parameters colors?
LT401Vette
Re: Changing the third and fourth graph colors
Post by LT401Vette »
If you have 4 graphs with 4 selectors per graph.
On the Main Menu, select:
Options --> Graph Trace Color
The colors are listed per trace, Graph 1 should be 1-4, Graph 2 should be 5-8, Graph 3 should be 9-12, etc.
As you update the 1st 2, I think you know this so I assume this is not happening this way?
I just tried it and it seems Ok?
Marek
Post by Marek »
Is this a case where the menu disappears under the bottom of the screen because it is a laptop and it has a small screen, so you can't see the remaining menu options?
kind regards
Marek
