MLV bug: MLV shows 3 decimals after log-marker
Postby BigBlockMopar » Sun Oct 15, 2017 2:05 pm
(MLV 4.2.02)
Noticed a bug in MLV that it will start showing values with 3 decimal digits (x.000), instead of 1 (x.0), when there's a marker present in the log-file.
Before the marker, values are shown with 1 decimal.
After the marker, values are suddenly shown with 3 decimals.
Going back in the log to 'before the marker', MLV still keeps showing 3 decimals on all values.
Daily driver: 1973 Dodge Dart - 318ci engine / MS3x - ignition only. A518-OD transmission / 3.55 gears
BigBlockMopar
Re: MLV bug: MLV shows 3 decimals after log-marker
Postby LT401Vette » Sun Oct 15, 2017 2:53 pm
Can you post the log you are seeing this with?
LT401Vette
Postby BigBlockMopar » Sun Oct 15, 2017 3:06 pm
Ok, noticed a different behaviour too;
- in the first log (2017-10-14_18.40.36), only Spark advance and RPM values get 3 decimals after the marker.
The other values kPa, CLT and BattV for instance stay correct at 1 decimal.
In the other log, all values get 3 decimals after the marker (at least, the yellow line in the log, is when I cycled the ignition key off and on, for when I got in/out of the car).
2017-10-14_18.40.36.msl.zip
(174.91 KiB) Downloaded 2 times
2017-10-15_19.13.22.msl.zip
(244.44 KiB) Downloaded 2 times
BigBlockMopar
Postby BigBlockMopar » Sun Oct 15, 2017 5:30 pm
I think I've narrowed it down to "Time Gap: Calculated Record".
In a log, once you scroll across that area, the 3 decimals appear and don't go away anymore in any other part of the log.
BigBlockMopar
Return to Megalogviewer
