MLV HD updated now will no open RPI3
Postby Gavin Lodewick » Sun Nov 19, 2017 4:55 pm
Hi I have updated MLV/HD and now it will not open, I have downloaded from EFI downloads aswell tar file for RPI3, and it still will not open. please help. :?
Gavin
Gavin Lodewick
Re: MLV HD updated now will no open RPI3
Postby LT401Vette » Tue Nov 21, 2017 11:43 am
update to a 1.8 JRE or install the JavaFX libraries if you are using Open Java
LT401Vette
Postby Gavin Lodewick » Tue Nov 21, 2017 10:32 pm
Hi Phil, new to rpi3 will search for
LT401Vette wrote:update to a 1.8 JRE or install the JavaFX libraries if you are using Open Java
and update.
Gavin
Gavin Lodewick
Postby Gavin Lodewick » Fri Dec 08, 2017 8:34 am
Hi Phil
still struggling with this, I have installed the latest 1.8 JRE 8u151 java. I struggling with JavaFX libraries.
I see the latest TunerStudio Ultra works on the RPI now, is this the same problem with MLV HD.
Please Help, so I can start Tunning. :idea:
Gavin
Gavin Lodewick
Postby DaveEFI » Fri Dec 08, 2017 9:05 am
When I've had this problem, trying installing a freshly downloaded version of TS or MLV from the official site That seems to sort out any Java funny. Even when it updates after doing this. You don't need to uninstall the old, and all your own files are kept.
DaveEFI
Postby LT401Vette » Fri Dec 08, 2017 1:52 pm
DaveEFI wrote:When I've had this problem, trying installing a freshly downloaded version of TS or MLV from the official site That seems to sort out any Java funny. Even when it updates after doing this. You don't need to uninstall the old, and all your own files are kept.
The only way that will fix it is if an auto update went bad, which is pretty hard these days.
Otherwise you are just deleting files then putting the same ones back and wasting your time.
LT401Vette
Return to Megalogviewer
