Bloody filter!!!
Bloody filter!!!
Postby danbeck » Mon Dec 18, 2017 4:46 am
Hi guys
I can't Ve analyse because it keeps saying my log was 99 percent filtered!! Due to min clt values.
I have tried setting to very low levels to avoid filter, and have filter turned off
Really frustrating because I can't tune!!
It's a 911 Porsche 2.7 with ms2
Suggestions?
danbeck
Re: Bloody filter!!!
Postby jsmcortina » Mon Dec 18, 2017 5:03 am
:msq:
Postby Suprazz » Mon Dec 18, 2017 5:29 am
I guess that you have a fixed temperature because there is no or you didnt connect the temp sensor.
Check your temperature value, and adjust filter to it.
Suprazz
Postby danbeck » Thu Dec 21, 2017 11:26 pm
Sorry guys
Heres a log
Hope it helps as its preventing me from using the tuning functions of megalog
I know its not running as well a sit could be but any advice is much appreciated
Cheers
Dan
2017-12-11_13.55.31.msl
datalog 911
(1.48 MiB) Downloaded 7 times
danbeck
Postby kjones6039 » Fri Dec 22, 2017 12:08 am
I see a couple of odd things in that log.
I'm thinking we still need to see your tune file (msq)!
MS2 v3 w/extra 3.4.2 Release
kjones6039
Postby danbeck » Fri Dec 22, 2017 4:38 am
here it is
2017-12-22_22.06.11.msq
(118.98 KiB) Downloaded 8 times
danbeck
Postby kjones6039 » Fri Dec 22, 2017 10:59 am
No TPS or IAT sensor?
kjones6039
Postby danbeck » Fri Dec 22, 2017 11:57 pm
Hi Ken
I do have tps but whats the other one?
As you can tell I'm new at this!!
danbeck
Postby Dennis_Zx7r » Sat Dec 23, 2017 5:46 am
IAT or MAT refer to Intake Air Temperature or Manifold Air Temperature; they're the same. Basically the temperature of the air before it enters the engine.
danbeck wrote:I can't Ve analyse because it keeps saying my log was 99 percent filtered!! Due to min clt values.
This seems to be an issue with what you set for your filter criteria. I can use VEA just fine using your datalog and MSQ.
My build (german, page 5+): Link
Dennis_Zx7r
Postby danbeck » Tue Dec 26, 2017 5:51 am
Thanks for the feedback guys and Merry Christmas!!
I'm so green at all of this. I really underestimated how challenging tuning is...
If I could get the megalog to stop telling me my log was filtered Id have a shot
What am I doing wrong??
Ive attached a couple of photos
Image022 by Dan Pfitzner, on Flickr
Image023 by Dan Pfitzner, on Flickr
Image024 by Dan Pfitzner, on Flickr
danbeck
Postby jsmcortina » Tue Dec 26, 2017 6:22 am
What coolant temperature are you seeing? From the message it must be wildly inaccurate or you are in Siberia?
If your basic sensors aren't reporting accurate numbers you MUST fix that before trying autotune.
Postby Dennis_Zx7r » Tue Dec 26, 2017 8:59 am
I think this might be more of an issue with the negative number he put in.
His CLT in the log seems reasonable and it worked just fine on my version of MegaLogviewer and MinCLT 60.
Edit: I also just tested this with the -22 he entered in the screenshot, and this still works fine on my computer. As I already said I'm using MLV though.
His CLT varies between 150 and 170°F, so this seems to be in order.
Dennis_Zx7r
Postby danbeck » Wed Dec 27, 2017 2:42 am
It didn't matter if I posted a low positive number or put in -22 (just to get it away from filtering)
Is there anything else that could be a problem?
Maybe Ill try again? There must be a reason this is being filtered
Thanks for your feedback
danbeck
Postby danbeck » Thu Dec 28, 2017 6:03 pm
I worked it out!!!
Had to go into another menu
Thankyou for all of you help. See you next crisis
danbeck
Return to Megalogviewer
