Export Loaded Log As
Postby W126 » Fri Dec 22, 2017 10:22 pm
I've exported a log but don't see any difference compared to the original.
What does Export do, is it just copy ?
W126
Re: Export Loaded Log As
Postby kjones6039 » Sat Dec 23, 2017 9:24 am
If I'm not mistaken, Export is equivalent to Save As, which simply allows you to provide your own file name.
MS2 v3 w/extra 3.4.2 Release
kjones6039
Postby W126 » Sat Dec 23, 2017 9:30 am
so it's the same as copying the file ?
W126
Postby jsmcortina » Sat Dec 23, 2017 9:34 am
As far as I'm aware, if you trimmed the log, the Export will save that shorter trimmed version.
Postby kjones6039 » Sat Dec 23, 2017 9:49 am
W126 wrote:so it's the same as copying the file ?
For the most part.
jsmcortina wrote:As far as I'm aware, if you trimmed the log, the Export will save that shorter trimmed version.
And that also.
kjones6039
Postby LT401Vette » Mon Jan 01, 2018 9:54 am
As James said.. If you have edited the content of what is loaded, it will save what is now loaded.
So if you Trim after cursor, before cursor, etc... Those parts are gone and will not be saved.
Also your calculated fields will be saved to the new file..
LT401Vette
Postby W126 » Mon Jan 01, 2018 10:12 am
thank you Phil
W126
Return to Megalogviewer
