Log numbers have changed
Itsturbotime
Post by Itsturbotime »
I've been using megalogviewer for a few years now. Suddenly the PSI and MAP are showing way too high, 32psi high. Even on my older logs which I know where max 15 psi they are showing double the number. Is this a settings issue ? Any help would be appreciated.
T2_66.99_.msl
sample log attached from a hillclimb
(446.98 KiB) Downloaded 28 times
Brian H EFI
Re: Log numbers have changed
Post by Brian H EFI »
I took a look at your data log and the values are in normal range so I would like to take a look at your MLV properties file. Could you please go to the directory below and email the file named mlvUser.properties for MegalogViewer MS or hlv.properties for MegaLogViewer HD to support@efianalytics.com with a link to this forum post for reference.
C:\Users\Your PC User Account Name\.efiAnalytics
