It doesn't happen very often but I'd just like to know if there's any common causes for this and what I should be looking for? Doesn't seem a massive issue but obviously don't want it to happen when I'm at WOT at high rpm!
Unfortunately I don't have a log, it's that intermittent that it never seems to happen when I am logging! Just my luck! Doh!
Ecu is MS2 V3 running ms2extra 3.3.0b gslender v2.4.3 firmware. Car is a '90 MX5 1600 with ITB's running on the standard coil pack igntion with igniter.
Any suggestions would be great but if logs are needed I'll try and log each drive until it happens again.
