OEM Toyota 1NZ-FE Ignition System, need help.
Postby maxthehax » Tue Aug 07, 2012 7:28 am
Hi everyone. I own a 2005 Toyota Echo (Yaris/Vitz) powered by a 1NZ-FE engine. Using half of a patch harness Im planing using the OEM electrical harness to wire-up the MS-2... Anyway, main concern right now is the Ignition system.
This is a 4 cylinders, using 4 Coil On Plug setup. COP have 4 wires each. Built in ingnitors.
What I know so far about the OEM fonctionning of these COP;
1.ECM receives signals from CAM sensor, CRANK sensor & various sensors.
2.ECM sends signals to COP through IGT1,IGT2,IGT3,IGT4. This is a pulse generation, the waveform show a 2V/DIV., 20msec/DIV.
3.ECM receives a confirmation signal from Coils (IGF) (Maybe this is the signal GND??)
4.By Using the OEM electrical harness, when ignition switch is on, I should have a 12V constant to each COP.
5.GND is GND
So far I know I need to make MOD to my MS-2 v3.00 to make them work. Ive been told its a ``5V PNP drive mod``.
I have the documentation about making the MOD, but no infos about how I wire everything on which pin of the DB37..???
Thanks, any help is very appreciated.
maxthehax
Re: OEM Toyota 1NZ-FE Ignition System, need help.
Postby SimonKho79 » Thu Aug 09, 2012 10:41 pm
Nice to know someone who is using MS2 V3 on a 1NZ-FE.
I just did one to my customer's Yaris. Running wasted spark setup.
Here's what I did:
Combine the signal wire of the COPS as 2 pairs.
* IGT1 + IGT4 --> Ignition Output from your Channel A 5V PNP mod
* IGT2 + IGT3 --> Ignition Output from your Channel B 5V PNP mod
Make sure you change the ignition setting to "Wasted Spark", "Going Low" in TunerStudio
Hope it helps.
Cheers!
Simon
SimonKho79
Postby maxthehax » Sat Aug 11, 2012 11:37 am
SimonKho79 wrote:Hi,
Here's what I did:
Hope it helps.
Cheers!
Simon
Cool thanks! That part is perfect. By the way, where are you located?
What about the IGF (signal going from COP back to ECU)??
After reading a lot more. I think that IGF (E5 - 23 of ECM terminal) is the SIGNAL GND. So it would simply wire to a GND pin.
But why IGF exist on the oem terminals if its simply get back to ECU to get grounded...??
The description of IGF is: Ignition coil and igniter (ignition confirmation signal).
IGF is grounded at the same place of all IGT's
maxthehax
Postby Vicoor » Sat Aug 11, 2012 3:19 pm
The IGF signal is an ignition confirmation. In Toyota school they called it "I Got Fire".
It's a square wave back to the factory ecu when the ignitor in the stock coil works.
If it is not present the stock ecu will shut down the injectors to prevent flooding the catalyst with fuel.
For a MS application you should be able to just not use those signals.
Or you may be able tie the IGF terminals from all the coils together and use that signal for a tachometer
Don't Talk About it,,,Just Do It!
1993 Toyota P/U 22RE V3.0 MS2/Extra 3.2.4 Full sequential Injection & Spark
Vicoor
Postby maxthehax » Sun Aug 12, 2012 8:55 am
Vicoor wrote:The IGF signal is an ignition confirmation. In Toyota school they called it "I Got Fire".
Cool! Thanks a lot! So IGF signals could simply be ignored.
So in overall, all IGT1,2,3,4 will be going to Spark output of MS
The GND will be grounded at ms's gnd pins.
12V will be applied when ignition switch is on (Im using the OEM electrical harness)
That looks perfect. But last question is; the signal going from MS to COP (SPark X output), dont it need a signal gnd? I know there is already a ground but I though it was for the 12V current...
maxthehax
Postby Vicoor » Mon Aug 13, 2012 7:09 pm
The ground is for the primary Ignition circuit. Ground it to the cyl head/ manifold with the other grounds.
Vicoor
Users browsing this forum: No registered users and 5 guests
