spare outports not working
I have been having the hardest time making the IAC1A control my fans. I cant make it work. So i took the case back apart. I noticed something and remembered something at the same time. I began following the megamanual when first assembling then heard not to use it. I have a ford PWM warmup idle valve so i built that circuit off of Q4 and it works fine. BUT, i can see where i installed Q20 and must have removed it. I also have S12c jumpered as per the instructions. Are Q20 and R39 needed for the spare outputs to work?
Re: spare outports not working
Those are only needed for their own particular circuit, and don't affect the IAC pins. Are you trying to drive the fans directly or through a relay? Which IAC1 pin are you using? Please post your msq.
I am trying to use the IAC1A and 2A to send signal to the relay. I have it hooked up and wired exactly how i have done it in the past with good results. On my other car i have the relays grounded and use the IAC to send 12 volts to the relay. Works great. But i have had nothing but trouble with this one. So idk, maybe i got the board hot in one spot while soldering or something. I will attach the msq in a seperate post, it is on my laptop.
here is msq. Im using tunerstudio 2.5.05
I got tired of beating my head against the wall. I just constructed the "relay mod" circuit off of D15, fan works perfect. I must have somehow damaged the IAC circuits while soldering or something. Oh well, this car only needs two spare outputs, fan and water injection. Ill just build another relay mod circuit and call it a day
I'm not convinced of that yet....... In your msq you have the Power On Value set to on and the Active Value set to off for IAC1. Are you sure that's the way you want it?I must have somehow damaged the IAC circuits while soldering or something.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
