I seem to remember reading that it's no longer needed to modify the ms2 board to do table switching (or was it launch control)?
Been looking for info on this but I can't find it.
Was I dreaming or is the mod indeed no longer needed?
Launch isn't really a problem but TS has always been a pain to do.
table switch (or launch) without daughterboard modification?
Re: table switch (or launch) without daughterboard modificat
Launch control has been available for a while on JS4, 5, 10, and 11. Table switching has recently been added to JS7; this still requires a mod to the card, but it's the much simpler - and safer! - JP4 (PE0) to pin 10 jumper.
thanks, exactly what I was looking for. Found it in the latest alpha.
tengo problemas:
Ya hice el puente desde pin15 al procesador tal como muestra el manual con
el cable amarillo. Retire R1 e hice el circuito "active low".
aun asi no consigo el cambio de mapas
help please
help please
Have you selected 'Hardware' for Switch Source, and 'PE1' for Switch location? The yellow pin in the picture is going to PE1, while JP4 is connected to PE0.9alex16v wrote:tengo problemas:
help please
[Google Translate}
I have problems:
I already made the bridge from pin15 to the processor as shown in the manual
the yellow cable. Remove R1 and made the circuit "active low".
even so I do not get the map change
[Google Translate]
¿Ha seleccionado 'Hardware' para el interruptor Fuente, y 'PE1' para la ubicación del interruptor? La clavija amarilla en la imagen se va a PE1, mientras JP4 está conectado a PE0.
