Need help on a problem....
Well had a perfectly good running car on Ms2 v3...all of a sudden after a year I started to have a issue. The car all of sudden started stalling and then wouldn't start. If I spray starting fluid it will start and appear to drive fine.
Here is the data log and msq file..any help would be appreciated thanks.
Re: Need help on a problem....
Whats going on with your tps sensor??? highest was 109% lowest was 82%???? your flood clear is set for 35% so if the engine is cranking and the tps is 35% or more it will not inject fuel.
Thanks a lot..ive already checked the ohms on the tps and it checks out perfectly. What would cause something like that..moisture,oil in the tps. Maybe excessive noise or something ? Bad connection or ground ? Its a e30 bmw with m20 turbo engine..so I'm glad you responded as i see you have the same car...
is it the stock tps? as they are not variable, cold be looking at a bad ground to it
It is a variable one from a m50 motor. Going to dig around look for a bad ground. Thanks ...gonna continue with this tomorrow ..fresh and early in the morning.
Pardon my ignorance, but would recalibrating the TPS be of any help in resolving this issue ?
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
it may well help if its just the calibration data that has gotten messed up some how.
Gonna look around for a bad ground..and attempt to recalibrate the Tps also thanks guys.
Re: Need help on a problem....RESOLVED
Well, it was my fault....the car has been running beautifully for the last 3 weeks...just wanted to update because I think it's important to do so. I had accidentally plugged in the wrong connector to the tps ...yeah I know ..stupid. It's just that the guy who wired this up before I bought the car had spliced into the harness and so there where extra plugs snd I screwed up. Anyway thanks to all that helped and to Matt especially.
