A test of the opto circuit sounds like a good idea & I was thinking it might be more productive to pursue the "coil negative" method here and wondered how your connection at the coils was made? (due to them being twin 6v and connected in series). I suspect you are running the bike (or cranking with plugs removed) to test the signal recognition? I'd be yet tempted to leave everything hooked up, with the exception of the bean can which I'd jerry rig a simple hand drill drive for once unbolted from the cam (black plastic tape, wooden dowels onto the offset hub, on a small drill bit come to mind) and in that way try all manner of combinations of connections and settings while having the diagnostics in TS and tooth logger enabled to coax out a signal. I haven't done anything with the simple coil negative triggering so I can't really comment on how she works.LAV1000 wrote:Are you sure the opto circuit is working ?
You could test it this way.
Connect opto- to ground.
Connect opto+ to 1K resistor.
Connect other end of 1K resistor to testlead (- black) of an multi meter.
Put multimeter in "mA" and put the testlead (+ red) to 12Vdc (battery)
You should measure around 8mA.
Ther's also an other way but that requiers a led and 2 1k resistors in paralell.
You can use this instead of multi meter and 1K resistor.
Led needs the +Vdc on a certain wire so maybe you have to reconnect it the other way.
It won't damage if it is backward in this circuit.
About the coil.
If you have a coil whit 1 primairy set of wires (+12Vdc and grounding/switched) and 2 plug outputs,
you only need 1 diode and resistor.
I was going to compare some settings but my old Dell lap top seems to have experience the "black screen" of display this morning and won't come to life as she boots , plugged a second screen in & your settings seem in order.
Hope to see some photos of things as you move past this initial hickup.
Lorne
