Car/ms info: 94 miata ms2 extra with jbperf sequential ignition and injection board. using toyota cop
My trigger pulse for my spark is stuck at 5v. I checked my wiring and it seems like everything is ok. Is there a setting in tunerstudio or did i mess up assembling my board?
any help appreciated
thank you
spark trigger stuck at 5v
Re: spark trigger stuck at 5v
Hall sensor pull up voltage?
Is hall sensor getting power?
There's no setting in tuner studio. Sounds like you wired +5 volts to the JBperf board. Try +12 v instead.
-Alex
-Alex
Don't do that.16vboost wrote:Sounds like you wired +5 volts to the JBperf board. Try +12 v instead.
First, you need to give a LOT more information about your setup and your settings. We have next to nothing with your post. Is it a logic-level setup? And where did you measure 5V? Have you tried the test mode.
And:
i am sorry for wasting your guys time . i miss understood the concept of coils and figured it out.
No time wasted. We're here to help each other.
