Engine dies when connect to TunerStudio. Solved.
Hello.
Engine with 36-1 trigger wheel with hall and stock distributor.
I have a problem, i use ms2 firmware 3.3.3, when i connect pc with tunerstudio to engine, engine just dies, gets lost sync, engine stops, Tuner studio stays online. Tried with rs232 to usb cable, the same, tried with bluetooth dongle, the same, reinstalled tunerstudio - the same, tried connect via bluetooth to msdroid (phone) happens the same, engine dies just after connection is made, about 5 seconds. If i start engine without connection to pc or msdroid via bluetooth everything runs fine. Tried different firmware too, got the same.
any suggestions? Problems with 5v supply maybe? Hall takes 5v from tps wire.
Re: Engine dies when connect bluetooth.
I have that same adapter which I use in TS and MSDroid with no problem at all For 3 years. My MS2 has 3.3.1 installed. Try installing the previous firmware.
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark with MSD coilpack, dual table, launch control and 3.88 tranny. Anyway, runs great can't be more reliable than this. All done by me... t03 running 48lb. Injectors, Intercooler, W/M injection at 15psi for now.
Re: Engine dies when connect to TunerStudio.
Here is msq and log.
Is the laptop powered from the car's electrical system or on battery power?
Laptop is powered from battery, i tried msdroid from phone via bluetooth the same happens. I ordered ST232ABN, will try to replace.
Is your hall sensor is designed for a 5V power supply? Many are 12V.
My hall sensor is Cherry VN101503, in datasheet it says "Supply Voltage 3.8 to 24 VDC" If i set data rate in tuner studio to 0 reads per second, engine runs normally, if i set to 1 reads per second, after about 30 seconds engine dies, if i set 15 reads per second then after 5 sec engine dies.
Problem solved after replacing ST232ABN.
