MS2 5 Volt issues
MS2 5 Volt issues
So my megasquirt has been intermittently just not powering on!
I've traced the issue down to the 5 volt bus is only measuring 2.2 volts.
I disconnected the tps in case that was the fault, and with everything but power disconnected it still exists.
D19 is measuring 2.2 volts on one side and about 600 ohms across.
C22 also measures 600 ohms.
D19 is measuring 12 volts on high side, and 2.2 volts on the other side.
Please help!!
Please help!!
Re: MS2 5 Volt issues
Is the regulator getting hot? Does the regulator have a good connection on it's ground pin?
Cheers Luke
Cheers Luke
It's the pcb 3.57 pre assembled. What's regulator labelled as?
Should be U5. http://www.msextra.com/doc/pdf/html/MS2 ... 4-171.html
Cheers Luke
Cheers Luke
Is that all I should be looking for? Is it common to see less than 5 volts when regulator goes?
It is not common to have a faulty regulator. They are fairly robust device.
Cheers Luke
Cheers Luke
IMHO, an intermittent fault like this is far more likely on the external 5v wiring than in MS itself. Unless you are seeing the fault on the bench with just a Stim connected.
If it only happens on the car, I'd be inclined to arrange an easy way to measure the current in the 5v to the sensors, etc. A breakout board can be very useful for this.
So my megasquirt hooks up to an amphenol connector for sensors then it gets power separately, the fault exists with all my sensors unplugged.
So my symptoms are definitely a 5 volt fault?
Sensors unplugged still leaves the wire harness. Which is where the problem is most likely.
Pulling too much current (a short or overload) should cause a lot of heat in the reg and make it shut down.
Cheers Luke
Cheers Luke
No faults in this connector..
Nothing warm on U5, my fuel injectors are ticking... Which is kind of odd..
JS12:
JS12C: 2.50
Q9: 11.53
Q12: 11.57
D3: 11.50
U5: 2.53
D9: 2.55
S5: I think you are referring to JS5, I get 0.03, this is my tach output running to pad 7 on the db15
+5V holes: 2.48
D9: 2.4
U5: 2.5
D19: 0
Cpu pins 1,20,31: 2.5 volts
JS12C: 2.50
Q9: 11.53
Q12: 11.57
D3: 11.50
U5: 2.53
D9: 2.55
+5V holes: 2.48
D9: 2.4
U5: 2.5
D19: 0
I also tried removing d19 but no change
Was there voltage at S12? If there was 12V there and S12C is 2.5v then look at C16 or D12.
Cheers Luke
Cheers Luke
I couldn't find S12. Unless you mean JS12
Just measure both sides of D10. It's anode side should be 12V and cathode side should be what you see at S12C.
Cheers Luke
Cheers Luke
And if that's bad what is my issue?
It should be about the same as you got for Q9 Q12 D3 on the anode side. Just trying to be thorough. C16 or D12 are what I would suspect pulling the voltage to the regs input down. If you had the MS2 daughter card out checking voltages then it is unlikely the IAC driver could be involved.
Cheers Luke
Cheers Luke
I didn't have daughter board out but I will check again!
