Haha James I will, my first post here was to the OP. I have a couple things I'm gona try or test before I start a new thread....jsmcortina wrote:Start a new topic then.
Sent from my SCH-I545 using Tapatalk
I am beginning to think that you are correct. I have been slavishly reading the manual and posts in the support forum related to this issue and noticed that my ignition input capture setting is currently set to "falling edge", and according to the manual it should be set to "rising edge". I came across this reading several other threads related to this issue (http://www.msextra.com/forums/viewtopic ... 01&t=47361), and a post in yet another related thread by the author of the first thread here (http://www.msextra.com/forums/viewtopic ... 2&start=20). Put simply, this is apparently important and will piss off the computer if it is set wrong.Moody wrote:I don't think wiring is your problem because I have exactly the same problem with my microsquirt install but I'm using a vr sensor. Must be setting issue? I didn't have this problem when I was fuel only setup....
Ooh - GOOD CATCH. Yes, that looks to be the MS2 version of the firmware which won't work correctly on a Microsquirt.Moody wrote:Your firmware doesn't look right, it's not the same as the firmware I have loaded into my microsquirts....
Alright, so it looks like I am in fact losing sync then according to my composite logs above in my latest long post, or at least I am not getting any sync in the first place? I am not getting a cam pos signal since I am running wasted spark with no cam sensor, so that makes perfect sense. The image above simply shows a bunch of turquoise spikes. Why am I recording the square wave signal consistent with the LS1 24 tooth wheel in my composite log?jsmcortina wrote:See the image on this page:
http://www.msextra.com/doc/pdf/html/Meg ... .4-47.html
Thank you for confirming that for me hybrid, I appreciate it.hybrid wrote:Output to the coils has no bearing on whether you see a crank signal (as you have no doubt found out now).
You are doing the right thing to have the injectors and coils powered off until you know your ignition capture is good to go.
