PCB v3.0 mods
PCB v3.0 mods
Postby panel » Mon Mar 20, 2017 9:14 pm
If I was to use this mod to add a fan....how do you get the wire to the DB37 connector?
This is one example of what you can do, in this example I used the JS3 output from the MS-I CPU as the input into this circuit (telling it when to switch on/off) and the output routes to Jmp SPR1 which sends the signal out to the DB37 on pin3 which is a pretty good choice since on the v3 it’s not used for anything else. You’d then use pin3 on the DB37 to control your relay which controls your electronic doodad of choice — electronic fan.
Or if I used this boost mod....
Same here: Image
'65 VW Bus Turbo Subaru powered & MS pix CLICK
Running on MS1 since July 22/05,
MSnSExtra July/06 , EDIS Aug/06,
MS-II(upgrade) July 1/10...now...MS-II(upgrade) Extra Oct 10/10!
Sold it all 3 years ago and now getting back into it with a MS2 V3.0 Sept/2016
panel
Re: PCB v3.0 mods
Postby hybrid » Mon Mar 20, 2017 10:01 pm
There's SPR1-4 near the DB37. Which of these are available depends if you're using the canbus or what other mods may have already been done.
hybrid
Re: PCB v3.0 mods
Postby panel » Mon Mar 20, 2017 10:23 pm
Just about to build 2 fan circuits and one boost control. SPR1 (CANH) and SPR2(CANL) taken from step 23 (pg.193) of http://www.msextra.com/doc/pdf/MS2V30_Hardware-3.4.pdf
panel
Re: PCB v3.0 mods
Postby hybrid » Tue Mar 21, 2017 4:13 pm
Are you actually using CAN?
hybrid
Re: PCB v3.0 mods
Postby boofhead » Tue Mar 21, 2017 10:57 pm
Just install an extra DB15 into the case and use that as the feed for external IO.
Alternatively install an audio jack for Can usage and then you have spr1-4 for upto 4 I/O lines.
boofhead
Re: PCB v3.0 mods
Postby panel » Wed Mar 22, 2017 10:05 am
PM sent.
hybrid wrote:Are you actually using CAN?
panel
Users browsing this forum: kjones6039, twinturbor and 5 guests
cron
